[Gdal-dev] gdalinfo and mrsid
Clay, Bruce
bclay at ball.com
Wed May 16 15:12:02 EDT 2007
Gdalinfo does not report a coordinate system when used with MrSid
landsat images. Is this a known issue? It does report reference system
from some other MrSid rasters that I use. Is there a work around?
Bruce
Z:\GeoData\MrSid\N-17-35_2000>gdalinfo N-17-35_2000.sid
Driver: MrSID/Multi-resolution Seamless Image Database (MrSID)
Size is 47638, 39169
Coordinate System is `'
Origin = (160576.125000000000000,4433082.125000000000000)
Pixel Size = (14.250000000000000,-14.250000000000000)
Metadata:
IMAGE__INPUT_NAME=/dbuy/l7/outputs/mosaics742/N-17-3/locals/N-17-35_ll_7
42_200
0.tif,
/dbuy/l7/outputs/mosaics742/N-17-3/locals/N-17-35_lr_742_2000.tif,
/dbuy/
l7/outputs/mosaics742/N-17-3/locals/N-17-35_ul_742_2000.tif,
/dbuy/l7/outputs/mo
saics742/N-17-3/locals/N-17-35_ur_742_2000.tif
IMAGE__INPUT_FILE_SIZE=5627937020.000000
IMAGE__COMPRESSION_VERSION=1,6,3
IMAGE__TARGET_COMPRESSION_RATIO=29.999998
IMAGE__COMPRESSION_NLEV=8
IMAGE__COMPRESSION_WEIGHT=2.000000
IMAGE__COMPRESSION_GAMMA=1.000000
IMAGE__COMPRESSION_BLOCK_SIZE=4096
IMAGE__CREATION_DATE=Fri Sep 19 16:16:14 2003
IMAGE__WIDTH=47638
IMAGE__HEIGHT=39169
IMAGE__TRANSPARENT_DATA_VALUE=0,0,0
IMAGE__COLOR_SCHEME=0
IMAGE__DATA_TYPE=0
IMAGE__BITS_PER_SAMPLE=8
IMAGE__XY_ORIGIN=160583.250000,4433075.000000
IMAGE__X_RESOLUTION=14.250000
IMAGE__Y_RESOLUTION=14.250000
Corner Coordinates:
Upper Left ( 160576.125, 4433082.125)
Lower Left ( 160576.125, 3874923.875)
Upper Right ( 839417.625, 4433082.125)
Lower Right ( 839417.625, 3874923.875)
Center ( 499996.875, 4154003.000)
Band 1 Block=1024x128 Type=Byte, ColorInterp=Red
Minimum=6.000, Maximum=199.000, Mean=89.353, StdDev=25.490
Overviews: 23819x19585, 11910x9793, 5955x4897, 2978x2449, 1489x1225,
745x613,
373x307, 187x154
Band 2 Block=1024x128 Type=Byte, ColorInterp=Green
Minimum=7.000, Maximum=212.000, Mean=147.673, StdDev=18.278
745x613,
373x307, 187x154
Band 3 Block=1024x128 Type=Byte, ColorInterp=Blue
Minimum=33.000, Maximum=245.000, Mean=86.940, StdDev=21.528
745x613,
373x307, 187x154
Metadata:
42_200
0.tif,
/dbuy/
/dbuy/l7/outputs/mo
IMAGE__WIDTH=47638
IMAGE__HEIGHT=39169
IMAGE__DATA_TYPE=0
Corner Coordinates:
745x613,
373x307, 187x154
745x613,
373x307, 187x154
745x613,
373x307, 187x154
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070516/3b0253bb/attachment.html
