[Gdal-dev] gdal_translate problem with NITF RGBA image
John Bowen jbowen at BlackbirdTech.com
Thu May 17 09:46:29 EDT 2007
I'm trying to convert a 16bpp, 4 band NITF image into a GeoTiff and have
not been able to figure out the arguments necessary to properly convert
it.  Accompanying the NITF image is a text description of the image,
which contains (parts edited out with <snip> and </snip> for brevity:
version = "AA";
generationTime = 2006-12-16T01:13:10.000000Z;
productOrderId = "005590231010_01_P002";
productCatalogId = "901001000E567E00";
childCatalogId = "202001000E567D00";
imageDescriptor = "Basic1B";
bandId = "Multi";
panSharpenAlgorithm = "None";
numRows = 2187;
numColumns = 6876;
productLevel = "LV1B";
productType = "Basic";
numberOfLooks = 1;
radiometricLevel = "Corrected";
bitsPerPixel = 16;
compressionType = "None";
BEGIN_GROUP = BAND_B
<snip>
</snip>
END_GROUP = BAND_B
BEGIN_GROUP = BAND_G
<snip>
</snip>
END_GROUP = BAND_G
BEGIN_GROUP = BAND_R
<snip>
</snip>
END_GROUP = BAND_R
BEGIN_GROUP = BAND_N
<snip>
</snip>
END_GROUP = BAND_N
outputFormat = "NITF20";
BEGIN_GROUP = IMAGE_1
<snip>
</snip>
END_GROUP = IMAGE_1
END;
When I try to convert it with gdal_translate, the resulting TIF file is
not viewable.  The image produced contains 1 pixel wide bands of various
colors, that from a 1x zoom level appear to be gray.  The output of
tiffinfo on this GeoTiff file produces the following:
TIFFReadDirectory: Warning, test.tif: unknown field with tag 34264
(0x85d8) encountered.
TIFFReadDirectory: Warning, test.tif: unknown field with tag 34735
(0x87af) encountered.
TIFFReadDirectory: Warning, test.tif: unknown field with tag 34737
(0x87b1) encountered.
TIFFReadDirectory: Warning, test.tif: unknown field with tag 42112
(0xa480) encountered.
TIFF Directory at offset 0x72cd27e (120377982)
  Image Width: 6876 Image Length: 2187
  Bits/Sample: 16
  Sample Format: unsigned integer
  Compression Scheme: None
  Photometric Interpretation: min-is-black
  Extra Samples: 3<unspecified, unspecified, unspecified>
  Samples/Pixel: 4
  Rows/Strip: 1
  Planar Configuration: separate image planes
  Tag 34264:
0.000033,-0.000000,0.000000,-77.147100,-0.000001,-0.000024,0.000000,38.8
59040,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,1.0
00000
  Tag 34735:
1,1,0,5,1024,0,1,2,1025,0,1,1,2048,0,1,4326,2049,34737,7,0,2054,0,1,9102
  Tag 34737: WGS 84|
  Tag 42112: <GDALMetadata>
  <Item name="NITF_FHDR">NITF02.00</Item>
  <Item name="NITF_CLEVEL">06</Item>
  <Item name="NITF_STYPE"></Item>
  <Item name="NITF_OSTAID">DG</Item>
  <Item name="NITF_FDT">16011310ZDEC06</Item>
  <snip>
  </snip>
</GDALMetadata>
Any ideas how to convert this file to GeoTiff correctly?
Thanks,
John
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070517/08a26c08/attachment.html
