[Gdal-dev] AAIGrid projection info
Sheykhet, Rostic
rsheykhet at sanz.com
Mon May 21 19:31:41 EDT 2007
Hi Frank/All,
I am looking at a potential bug in ESRI SRS transform for AAIGrid, and
just want to double check my assumptions. Currently, for Projection
TRANSVERSE in file ogr_srs_esri.cpp the projection parameter order is
assumed as follows:
PARAM_2 -> Latitude
PARAM_3 -> Longitude
PARAM_1 -> Scale
PARAM_4 -> False Easting
PARAM_5 -> False Northing
In the file below, and several others like it, I see that PARAM_2 is
actually Longitude and PARAM_3 is Latitude.
I am having difficulty locating any description for what a prj.adf file
should look like. If this, indeed, looks like a bug, I will file it in
TRAC and attach a patch file.
======================== prj.adf ==========================
Projection TRANSVERSE
Datum NAD27
Spheroid CLARKE1866
Units METERS
Zunits NO
Xshift 0.0
Yshift 0.0
Parameters
1.0 /* scale factor at central meridian
-106 56 5.149215 /* longitude of central meridian
39 33 45.40326 /* latitude of origin
0.0 /* false easting (meters)
0.0 /* false northing (meters)
========================= end prj.adf =========================
Thanks,
Rostic Sheykhet
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070521/5cb233ca/attachment.html
