[Gdal-dev] Use of gdalwarp/translate utility
Matt Wilkie matt.wilkie at gov.yk.ca
Tue May 22 14:03:14 EDT 2007
re:
>     http://trac.osgeo.org/gdal/wiki/UserDocs/GdalTranslate
> Thanks for this page, but I think it needs improvements. Its contents
> are quite redundant with the official doc of gdal_translate.
> I think of two possibilities :
> 1. Modify official doc of gdal_translate to get this point more clear.
Yes it would be cleaner to add that to the official docs, however I
don't have the ability to do that.  Now that it is written in the wiki
though perhaps someone with write access to the official docs will
insert it. :)
> 2. Transform this wiki page in a "HOWTO add geographic references
> (projection, coordinates) to an image using gdal_translate" with simple
> examples and explanations of commands used. This way the page would
> become a good add-on to the official doc.
I enthusiasticly encourage anyone/everyone to do exactly that! It is a
wiki after all (free osgeo login's at
http://www.osgeo.org/osgeo_userid/) . I certainly plan to do so myself
as those occasions arise in my work. :)
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
