[Gdal-dev] [OGR] Parsing GML using XSLT
Benoit Myard
myardbenoit at gmail.com
Wed May 23 04:46:58 EDT 2007
Hi list,
I guess I'm missing something but I haven't been able to successfully
parse OGR's GML with XSLT.
Sample OGR/GML file:
<?xml version="1.0" encoding="utf-8" ?>
<ogr:FeatureCollection
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://ogr.maptools.org/lightnings.xsd"
xmlns:ogr="http://ogr.maptools.org/"
xmlns:gml="http://www.opengis.net/gml">
<gml:boundedBy>
<gml:Box>
<gml:coord><gml:X>366874</gml:X><gml:Y>2130603</gml:Y></gml:coord>
<gml:coord><gml:X>387709</gml:X><gml:Y>2166975</gml:Y></gml:coord>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<ogr:lightning fid="F0">
<ogr:geometryProperty><gml:Point><gml:coordinates>371000,2
149000</gml:coordinates></gml:Point></ogr:geometryProperty>
<ogr:rowid>42</ogr:rowid>
<ogr:date>2007/01/21 01:16:45</ogr:date>
<ogr:nbstrokes>16</ogr:nbstrokes>
<ogr:amplitude>-1337</ogr:amplitude>
</ogr:lightning>
Sample XSL file:
<?xml version="1.0"?>
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
xmlns:ogr="http://gdal.velocet.ca/ogr"
xmlns:xs="http://www.w3.org/2001/XMLSchema">
<xsl:output method="text" />
<xsl:template match="ogr:lightning">
<xsl:value-of select="@fid" />
</xsl:template>
</xsl:stylesheet>
It seems to be related with the ogr namespace since the gml namespace
doesn't cause any problem. Any hints ?
Thanks.
Benoit Myard
