[Gdal-dev] gdal formats
Gong, Shawn (Contractor)
Shawn.Gong at drdc-rddc.gc.ca
Wed May 23 17:40:56 EDT 2007
Hi List,
Questions for gdal 1.4.0 on Linux
openev.sourceforge.net's Building gdal for Linux/Unix suggests that:
configure --with-libz=internal --with-png=internal
--with-libtiff=internal --with-geotiff=internal
The gdal/frmts/ contents include png/gtiff/libtiff
1) There is no libz under gdal/frmts/, but zlib instead. Is zlib=libz?
2) Since I have installed zlib/jpeg, I should set them as external,
right?
3) The gdal/frmts/ contents also include hdf4/hdf5/jpeg2000
Doest it mean that I can use these internal libraries? I thought that
HDF4/5 needs to be downloaded from HDF group.
4) Assume that internal hdf4/hdf5 support are ok, the followings lines
in GDALmake.opt need to be changed to:
# HDF4 Support.
HAVE_HDF5 = yes
HDF4_INCLUDE = -I$(frmts/hdf4)
# HDF5 Support.
HAVE_HDF5 = yes
HDF5_INCLUDE = -I$(frmts/hdf5)
Is this right? Do I need to add -L flags?
5) what about jpeg2000, do I need to download JasPer? Or
# JPEG-2000 Support via JasPer library.
HAVE_JASPER = yes
JASPER_INCLUDE = -I$(frmts/jpeg2000)
Do I need to change proj4 setting?
PROJ_STATIC = no
Thanks,
Shawn
