[Gdal-dev] Transparent PNG with color table (palette)
Ludwig M Brinckmann
ludwigbrinckmann at gmail.com
Mon May 28 12:30:34 EDT 2007
Thanks, you are a star.
I will see if that works for me and report back.
Regards,
Ludwig
On 28/05/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Ludwig M Brinckmann wrote:
> > Maybe this was a bit premature.
> > Unfortunately, the MEM dataset does not support the SetGCPs method, even
> > though the documentation says it 'should' .
> > (" Memory datasets should support for most kinds of auxilary information
> > including metadata, coordinate systems, georeferencing, GCPs, color
> > interpretation, nodata, color tables and all pixel data types.")
> Ludwig,
> I see your analysis is correct - the MEM driver actually lacked GCP
> support
> despite the docs. I have added this in trunk, if that is convenient for
> you.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070528/b32d283f/attachment.html
