[Gdal-dev] Newbie (ogr2ogr reprojecting NZMG to NZTM)
andrew.haywood at poyry.com
Mon May 28 20:13:42 EDT 2007
Dear List,
i am having some problems with reprojecting shapefiles from NZMG to NZTM.
I have copied the nzgd2kgrid0005.1gsb into the projlib directory (on my
Suse 10.2 installation it is in the
if i run the following command
ogr2ogr -f "ESRI Shapefile" north_island_nztm.shp 'FRWP/Active/38A08772
MfE_Mapping forest harvesting using MODIS satellite
data/GIS/LCDB2_North_Island_Forest_Classes.shp' -s_srs "+proj=nzmg
+lat_0=-41 +lon_0=173 +x_0=2510000 +y_0=6023150 +ellps=intl +datum=nzgd49
+units=m +nadgrids=nzgd2kgrid0005.1gsb +wktext" -t_srs EPSG:2193
then run the following
ogrinfo -summary north_island_nztm.shp north_island_nztm
i get the following output. Where the datum is "Mean_Sea_Level" - which i
suspect is incorrect. I thought the datum should have been NZGD2000. Any
help would be greatly appreciated.
best regards.
INFO: Open of `north_island_nztm.shp'
using driver `ESRI Shapefile' successful.
Layer name: north_island_nztm
Geometry: Polygon
Feature Count: 104978
Extent: (1518858.988989, 5392310.766727) - (2089515.826863,
6221064.447185)
Layer SRS WKT:
PROJCS["NZGD2000 / New Zealand Transverse Mercator",
GEOGCS["NZGD2000",
DATUM["Mean_Sea_Level",
SPHEROID["GRS_1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",173],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",1600000],
PARAMETER["false_northing",10000000],
UNIT["Meter",1]]
AREA: Real (19.5)
PERIMETER: Real (19.5)
NI_NZMG_: Real (11.0)
NI_NZMG_ID: Real (11.0)
LCDB1CLASS: Real (11.0)
LCDB1NAME: String (40.0)
LCDB2CLASS: Real (11.0)
LCDB2NAME: String (40.0)
WET_CONTEX: String (3.0)
HECTARES: Real (19.2)
TA_ID: Real (11.0)
TA_NAME: String (50.0)
REGION_ID: Real (11.0)
REGION_NAM: String (50.0)
This email and any files transmitted with it are confidential, may be legally privileged and are intended solely for the use of the individual or entity to whom they are addressed. If you are not the intended recipient, you are hereby notified that any use, distribution, or reproduction of the contents of this email is strictly prohibited and may be unlawful. If you are not the intended recipient, please notify the sender by return email and destroy all copies of the original message including any attachments thereto.
Thank you.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070529/1c5c80a5/attachment.html
