[Gdal-dev] Resample map from C#
Tamas Szekeres
szekerest at gmail.com
Tue May 29 17:13:08 EDT 2007
Tomas,
Currently the interface has only a limited support to this effort.
Some time ago the only option I've found have been described at this
ticket:
http://trac.osgeo.org/gdal/ticket/1469
However I had to apply a patch to make this feature work and I don't
know exactly whether it have eventually been fixed or not. I'd
appreciate you to make a test, and provide the comment about the
results to this ticket.
Best regards,
Tamas
2007/5/29, Tomas R <monshi at home.se>:
> Questions, questions. Hope someone will answer..
> Short one:
> Is it possible from C# to make use of GDAL to resample a map? Like
> GDALWarp can do from the commandline?
> Example?
> Yours
> Tomas
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
