[Gdal-dev] Connecting to PostGIS using rgdal
Mike Leahy
mgleahy at golden.net
Tue May 29 19:28:14 EDT 2007
Hello,
I am trying to see if I can access a table from PostGIS using rgdal in
the R statistics program. I've been able to read information from
shapefiles, as the example below demonstrates. However, whenever I try
to read from a PG connection, I get a message saying it cannot open the
file (also in my output below). I'm on WinXP, running R-2.5.0, rgdal
0.5-9 installed from CRAN, and I have FWTools 1.3.1 installed. Output
from ogrinfo (from FWTools) reports information from the same PG
connection/dataset I'm trying to access using rgdal without any trouble.
I'm wondering what step I've missed in the setup of R, rgdal, or
FWTools/GDAL. I have added the FWTools bin folder to my Path
environment variable, as well as added GDAL_DATA, but that doesn't seem
to help. Is there anything I'm likely to have missed? I checked the
output from ogrDrivers(), and it looks like PostgreSQL isn't included -
so would this mean that I have to compile rgdal myself? If so, are
there instructions for this?
Thanks in advance for any help,
Mike
> ogrInfo("d:/data/canada","popplace")
Driver: ESRI Shapefile number of rows 497
Number of fields: 18
name type length typeName
1 AREA 2 12 Real
2 PERIMETER 2 12 Real
3 POPPLACE_ 2 11 Real
4 POPPLACE_I 2 15 Real
5 UNIQUE_KEY 4 5 String
6 NAME 4 50 String
7 NAME_E 4 50 String
8 NAME_F 4 50 String
9 UNIQUE_K_1 4 5 String
10 UNIQUE_K_2 4 5 String
11 REG_CODE 0 2 Integer
12 NTS50 4 7 String
13 LAT 4 7 String
14 LONG 4 7 String
15 SGC_CODE 0 7 Integer
16 CAPITAL 0 3 Integer
17 POP_RANGE 0 3 Integer
18 MSID 0 9 Integer
> readOGR("PG: host=127.0.0.1 dbname=rgdaltest user=postgres
port=5432","pop")
Error in ogrInfo(dsn = dsn, layer = layer) :
Cannot open file
> ogrDrivers()
name write
1 AVCBin FALSE
2 CSV TRUE
3 DGN TRUE
4 ESRI Shapefile TRUE
5 GML TRUE
6 KML TRUE
7 MapInfo File TRUE
8 Memory TRUE
9 REC FALSE
10 S57 TRUE
11 SDTS FALSE
12 TIGER TRUE
13 UK .NTF FALSE
14 VRT FALSE
