[Gdal-dev] Error opening HDF file
Frank Warmerdam
warmerdam at pobox.com
Thu May 31 12:48:05 EDT 2007
Miguel wrote:
> Hello,
> I have a gdal compilation (release 1.4.0) with HDF4, HDF5 and Grass
> support. I have a test program that opens and closes some HDF4 image
> many times. The problem is when I have an HDF image wich has many
> subdatasets, Gdal crashes when is trying to open the image for the 31st
> time. That's the source code of my test program:
Miguel,
I suspect you are running into:
http://trac.osgeo.org/gdal/ticket/1485
This fix was done after the 1.4.1 release, but should be available in the
nightly svn-stable snaphots.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
