[Gdal-dev] Export shp to kml using ogr_csharp.dll
Leonidas Liakos
leonidas_liakos at yahoo.gr
Thu May 31 17:43:57 EDT 2007
Until now I manage to Open a Datasource and Create a Datasource.
The utility ogr2ogr converts shp to kml like that example:
ogr2ogr -f KML mypoints.kml sbpoints.shp
Question:
Is there any function which i can use to do tha progrmmatically OR I
have to iterate in all the features of the Opened Datasource(shp) to the
new Created DataSource(kml) and write each feature in that kml file?
My code until now:
Dim ogr As New OSGeo.OGR.Ogr
Dim kml As OSGeo.OGR.DataSource
Dim driver As OSGeo.OGR.Driver
Dim shp As OSGeo.OGR.DataSource
Dim options(0) As String
ogr.RegisterAll()
shp = ogr.Open("c:\Point.kml", 0) 'Open a Datasource
driver = ogr.GetDriverByName("KML")
options(0) = String.Empty
kml = driver.CreateDataSource("C:\Point.kml", options) 'Create a
Datasource
NEXT HOW TO IMPLEMENT ogr2ogr -f KML like in example?
Thank you for you help.Leonidas
