No subject
Wed Nov 21 11:48:46 EST 2007
culprit as it always fails because the file "projop_wparm.csv" cannot be
found.
Roger
------=_NextPart_000_0001_01C2DA15.2D967A40
Content-Type: text/html;
	charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html>
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 10 (filtered)">
<style>
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{margin:0cm;
	margin-bottom:.0001pt;
	font-size:12.0pt;
	font-family:"Times New Roman";}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
span.EmailStyle17
	{font-family:Arial;
	color:windowtext;}
@page Section1
	{size:612.0pt 792.0pt;
	margin:72.0pt 90.0pt 72.0pt 90.0pt;}
div.Section1
	{page:Section1;}
</style>
</head>
<body lang=3DEN-GB link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Frank,</span></font></p>
font-family:Arial'>&nbsp;</span></font></p>
font-family:Arial'>I create a new geotiff dataset, set the projection =
from wkt
that has projection parameters in it, and then save it. When I read it =
back in
the projection parameters are missing. For a transverse mercator these =
are things
like the lat/long origin and the false easting/northing etc. =
</span></font></p>
font-family:Arial'>From a quick look at the code the routine =
GTIFGetProjTRFInfo
might be a culprit as it always fails because the file =
&quot;projop_wparm.csv&quot;
cannot be found.</span></font></p>
font-family:Arial'>Roger</span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0001_01C2DA15.2D967A40--
