[Gdal-dev] [Fwd: strange problem compiling
against ndarrayobject.h]
Vincent Schut
schut at sarvision.nl
Thu Nov 1 04:05:51 EDT 2007
OK, rebuilding now, thanks for the fix! I was really frightened that I
had screwed up my numpy, or even worse, python build...
Cheers,
Vincent.
Mateusz Loskot wrote:
> Frank Warmerdam wrote:
>> Vincent Schut wrote:
>>> /usr/lib64/python2.5/site-packages/numpy/core/include/numpy/arrayobject.h:14,
>>> from extensions/gdal_array.h:10,
>>> from extensions/_gdal_array.cpp:33:
>>> /usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:92:2:
>>> error: #error Must use Python with unicode enabled.
>> Vincent,
>> At first I had no idea and assumed this was a Python 2.5 issue. But then I
>> ran into it on my system and discovered things were hosed by a change
>> Mateusz made last night. I have fixed
>> gdal/swig/python/extensions/gdal_array.h
>> in trunk now and things seem to be building ok for me.
>> Update, and try again.
> Frank,
> Yes, re-ordering headers broken numpy support.
> Thanks for fixing.
> Cheers
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071101/ecd1fb0a/attachment.html
