[Gdal-dev] Can't Read CCITTFAX 4 TIFs
Tom Kazimiers
2voodoo at gmx.de
Fri Nov 2 13:17:53 EDT 2007
Hi there,
I am using GDAL 1.4.3 and esp. GeoTiff for reading and displaying
GeoTiffs on Windows CE.
I successfully managed it to display GeoTiff Files that are LZW
compressed - other formats seem not to work.
The error message I get when trying to load CCITTFax (3 or 4 - both do
not work) compressed images is:
GetBlockRef failed at X block offset 0, Y block offset 0
RasterIO still returns 0 (so it seems as there occured no error - but
CPLGetLastErrorMsg() returns the message above.)
gdalinfo returns for the working image:
Driver: GTiff/GeoTIFF
Size is 62, 68
Coordinate System is `'
Metadata:
TIFFTAG_SOFTWARE=IrfanView
TIFFTAG_XRESOLUTION=508
TIFFTAG_YRESOLUTION=508
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
COMPRESSION=LZW
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 68.0)
Upper Right ( 62.0, 0.0)
Lower Right ( 62.0, 68.0)
Center ( 31.0, 34.0)
Band 1 Block=62x68 Type=Byte, ColorInterp=Palette
Metadata:
NBITS=1
Color Table (RGB with 2 entries)
0: 128,255,0,255
1: 251,13,0,255
For the same image (just compressed with CCITTFax4 - and black/white
colors) it returns:
Size is 62, 68
Metadata:
COMPRESSION=CCITTFAX4
Corner Coordinates:
Metadata:
NBITS=1
0: 255,255,255,255
1: 0,0,0,255
Everything is identical, but the the compression tag.
Do you have any hint what might have gone wrong?
Thanks in advance,
Tom
