[Gdal-dev] modis sinusoidal tiles: bug in gdal?
Frank Warmerdam
warmerdam at pobox.com
Tue Nov 6 09:36:14 EST 2007
Vincent Schut wrote:
>>> The puzzle:
>>> Then I tried to merge some modis tiles by using VRT, using vrt_merge.py.
>>> I was very puzzeled when I got an error message telling me it wouldn't
>>> merge my tiles because they did not have the same scale.
>> Vincent,
>> vrt_merge.py isn't part of GDAL - could you provide a pointer to the
>> version you are using?
> I know that. It is however a very valuable tool for me :-)
> I think I picked it up from the ml somewhere sometime long ago... Not
> easy to provide a pointer. Might have been this one:
> http://www.vso.cape.com/~nhv/files/gdal/gdal_vrtmerge.py, but I'm not
> sure. And I've adapted it to correct for an index error in the
> colortable support somewhere, if I remember correctly. And for
> ngbindings instead of ogbindings. I can send you a copy if you'd like.
Vincent,
I wouldn't mind incorporating it into GDAL, even if only in "samples" for
now. My main point is that it was hard for me to second guess the
vrt_merge.py aspects.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
