[Gdal-dev] SVN main trunk compilation woes on FreeBSD
Tom Russo
russo at bogodyn.org
Tue Nov 6 18:31:26 EST 2007
I had a few problems getting gdal from svn head to compile on BSD this weekend.
It's been a long time since I've updated gdal (I think the last time was
somewhere around a recent release, but still off the svn version), and I use
the python bindings.
My configure line was:
./configure --without-libgrass --without-grass --with-local=/usr/local --with-python
This gets me (ultimately) the configure output:
GDAL is now configured for i386-unknown-freebsd6.3
Installation directory: /usr/local
C compiler: gcc -O2
C++ compiler: g++ -O2
LIBTOOL support: yes
LIBZ support: external
GRASS support: no
CFITSIO support: no
PCRaster support: internal
NETCDF support: yes
LIBPNG support: external
LIBTIFF support: external (BigTIFF=no)
LIBGEOTIFF support: external
LIBJPEG support: external
LIBGIF support: internal
OGDI support: yes
HDF4 support: no
HDF5 support: no
KAKADU support: no
JASPER support: yes (GeoJP2=no)
ECW support: no
MrSID support: no
GRIB support: no
CURL support (wms/wcs/...):yes
POSTGRESQL support: yes
MySQL support: no
XERCES support: no
Expat support: no
ODBC support: no
PGEO support: no
OCI support: no
SDE support: no
DODS support: no
SQLite support: no
DWGdirect support no
PANORAMA GIS support: no
INFORMIX DataBlade support:no
GEOS support: yes
Old-gen python no
SWIG Bindings: python
Statically link PROJ.4: no
enable OGR building: yes
enable pthread support: no
enable debug mode: no
hide internal symbols: no
But when I build I get a ton of errors like:
libtool_args+=: not found
compile_command+=: not found
finalize_command+=: not found
and finally:
libtool: link: g++ /users/russo/src/gdal/.libs/libgdal.so -L/usr/local/lib /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so /usr/local/lib/libjasper.so -logdi31 -lgeotiff /usr/local/lib/libtiff.so -lm /usr/local/lib/libjpeg.so -lpng /usr/local/lib/libnetcdf.so -lpq /usr/local/lib/libcurl.so -lssl -lcrypto -lz -Wl,-rpath -Wl,/usr/local/lib
/usr/lib/crt1.o(.text+0x72): In function `_start':
: undefined reference to `main'
In the end I simply took the path of least resistance and use
"--without-libtool" to get past linker errors. I have no idea how to proceed
with libtool here, but I can live without it.
The other problem was that when built with the new python bindings I got a
make error ("don't know how to make build"). Building with --with-ogpython
worked.
Turns out the second problem is very simple to fix, and I'm attaching the patch.
FreeBSD does not have GNU Make as its default "make" program, you need to use
"gmake" to build gdal. But the swig GNUMakefile has a hard coded "make build"
(among other things) in its rules, where it should have "$(MAKE) build" so that
the actual make program in use gets propagated downward. With this attached
patch, I can build gdal on FreeBSD with the configure line:
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
Index: swig/GNUmakefile
--- swig/GNUmakefile (revision 12615)
+++ swig/GNUmakefile (working copy)
@@ -17,16 +17,16 @@
dist: generate
clean:
- for dir in ${BINDINGS}; do (cd $$dir; make clean ); done
+ for dir in ${BINDINGS}; do (cd $$dir; $(MAKE) clean ); done
veryclean:
- for dir in ${ALL_BINDINGS}; do (cd $$dir; make veryclean ); done
+ for dir in ${ALL_BINDINGS}; do (cd $$dir; $(MAKE) veryclean ); done
generate:
- for dir in ${ALL_BINDINGS}; do (cd $$dir; make generate ); done
+ for dir in ${ALL_BINDINGS}; do (cd $$dir; $(MAKE) generate ); done
build:
- for dir in ${BINDINGS}; do (cd $$dir; make build ); done
+ for dir in ${BINDINGS}; do (cd $$dir; $(MAKE) build ); done
install:
- for dir in ${BINDINGS}; do (cd $$dir; make install ); done
+ for dir in ${BINDINGS}; do (cd $$dir; $(MAKE) install ); done
