[Gdal-dev] How to scale an image
Sonson Sonson sonson25 at gmail.com
Fri Nov 9 11:59:28 EST 2007
Thanks Frank for your response.
I would like to do this at the API level.
Here is what I am trying to do. I am trying to read an image, set of
size 1000x1000 and write it to a new file of with a bigger size of say
1024x1024 or a smaller size like 512x512. Below a sample code of how I
try to achieve this. newsize is the width and length of my destination
image. I read an image, of size  rxsize x rysize, with
poBand->RasterIO(GF_Read, 0, 0, rxsize, rysize, data, dxsize, dysize,
eType, 0, 0); and create a file of size newsize x newsize, and later
write the pixed I read to the new file. I am sure there is something
wrong with the code, but I cannot seem to figure it out. Please help.
                               GDALDataset  *poDataset = (GDALDataset
*) GDALOpen( strInputFile, GA_ReadOnly );
				GDALRasterBand  *poBand = poDataset->GetRasterBand(1);
				//Load raster.
				char *data;
				nXSize = dxsize* dysize;
				data = (char *) CPLMalloc(nXSize*eType);
dysize,  eType, 0, 0);
				GDALDataset *poDstDS = poDriver->Create( filename, newsize,
newsize, bands, eType, papszOptions );
				poDstDS->SetGeoTransform( geotransform );
				poDstDS->SetProjection(projection);
				poDstDS->GetRasterBand(1)->RasterIO(GF_Write, 0, 0, rxsize,
rysize, data, dxsize, dysize,  eType, 0, 0);
				poDstDS->FlushCache();
				delete poDstDS;
On Nov 9, 2007 10:54 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Sonson Sonson wrote:
> > Hi all,
> > I have a question. I would like to know how to scale an image. I am
> > writing a program where I need to scale an image before processing it,
> > but I cannot find any sample program, or documentation on how to do
> > that. Say if my image's size is 6579x3289 pixel and I want it to be
> > scaled to 6656x3328, can anybody point me to documentation and sample
> > codes on how to do it.
> Sonson,
> What sort of sampling approach do you want to take?  If you just
> want nearest neighbour resampling you can do this as:
>    gdal_translate -outsize 6656 3328 in.tif out.tif
> or at the API level by specifying 6656,3328 as your buffer size when
> doing a RasterIO() to read into memory.
> If you want to control the resampling kernel you need to use the warp
> api.  At the commandline:
>    gdalwarp -rc in.tif out.tif -ts 6656 3328
> At the API level it is fairly involved. You could review:
>    http://www.gdal.org/warptut.html
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
