[Gdal-dev] How to scale an image
Sonson Sonson
sonson25 at gmail.com
Fri Nov 9 13:13:19 EST 2007
Sorry. I have added some inline comments.
Please see the code below.
GDALDataType eType = GDT_Byte;
GDALDataset *poDataset = (GDALDataset *) GDALOpen( strInputFile,
GA_ReadOnly );
GDALRasterBand *poBand = poDataset->GetRasterBand(1);
//Load raster.
char *data;
nXSize = dxsize* dysize; //Buffer size
data = (char *) CPLMalloc(nXSize*eType);
//rxsize and rysize are the size of the input dataset and dxsize *
dysize is the size in byte of the buffer
// That will store the read data in the data.
poBand->RasterIO(GF_Read, 0, 0, rxsize, rysize, data, dxsize,
dysize, eType, 0, 0);
//newsize is the size of my new image. It is very likely to be
different than rxsize and rysize.
GDALDataset *poDstDS = poDriver->Create( filename, newsize,
newsize, bands, eType, papszOptions );
poDstDS->SetGeoTransform( geotransform );
poDstDS->SetProjection(projection);
// I would like to write the data in a new image of size newsize.
Basically the idea is that,
// If rxsize and rysize are: 1000x1000 and newsize is 512x512
// I would like to have a new image that is scaled down to
512x512, but with the same data as
//the original 1000x1000 image.
poDstDS->GetRasterBand(1)->RasterIO(GF_Write, 0, 0, newsize,
newsize, data, dxsize, dysize, eType, 0, 0);
poDstDS->FlushCache();
delete poDstDS;
On Nov 9, 2007 12:17 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Sonson Sonson wrote:
> > Thanks Frank for your response.
> > I would like to do this at the API level.
> > Here is what I am trying to do. I am trying to read an image, set of
> > size 1000x1000 and write it to a new file of with a bigger size of say
> > 1024x1024 or a smaller size like 512x512. Below a sample code of how I
> > try to achieve this. newsize is the width and length of my destination
> > image. I read an image, of size rxsize x rysize, with
> > poBand->RasterIO(GF_Read, 0, 0, rxsize, rysize, data, dxsize, dysize,
> > eType, 0, 0); and create a file of size newsize x newsize, and later
> > write the pixed I read to the new file. I am sure there is something
> > wrong with the code, but I cannot seem to figure it out. Please help.
> Sonson,
> I'll add a few inline comments, but of course it is hard to judge from
> this subset.
> > *) GDALOpen( strInputFile, GA_ReadOnly );
> > //Load raster.
> > char *data;
> Can I just say, it is painful for me to see this variable name? How
> about nBufSize!
> You don't show what eType is, but if it is a GDALDataType value then this
> is wrong. You likely want (GDALGetDataTypeSize(eType)/8). GDALGetDataTypeSize
> returns the size of the passed data type (such as GDT_Float32) in bits.
Yes eType is GDALDataType of value GDT_Byte
> Can I assume that rxsize,rysize are the sizes of the source dataset, and
> dxsize,dysize are the desired output size?
rxsize and rysize are the size of the source dataset and dxsize and
dysize are just the size of buffer to read. The desired output dataset
size is newsize.
> Why aren't you creating the output file as dxsize,dysize instead of
> newsize,newsize?
> > poDstDS->GetRasterBand(1)->RasterIO(GF_Write, 0, 0, rxsize,
> > rysize, data, dxsize, dysize, eType, 0, 0);
> The data in "data" is already dxsize x dysize, so assuming the output file is
> dxsize x dysize you likely want to write it using:
> poDstDS->GetRasterBand(1)->RasterIO(GF_Write, 0, 0, dxsize, dysize,
My problem here, is that dxsize and newsize might be different.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
Thanks.
Sonson
