[Gdal-dev] Re: Gdal-dev Digest, Vol 42, Issue 15
Tim Keitt
tkeitt at gmail.com
Fri Nov 9 21:37:37 EST 2007
Michael Sumner <mdsumner <at> utas.edu.au> writes:
> In R the data is stored as a "data frame" - which is basically a list of
> same-length vectors that is matrix-alike via methods. (Real matrices in
> R are just vectors with a "dim" attribute and appropriate methods). For
> SGDF each row holds each pixel's value, one column per band. In R the
> data frame structure allows bands of different data type, a pathological
> GDAL scenario but very useful in R generally.
GDAL handles different data types per band just fine. Some file format drivers
may disallow different types, but the GDAL API does not have this constraint.
Re the original post, I don't use sp classes that often, but I assume there is a
method to convert a SGDF to an ordinary data frame or matrix. Simply call
readGDAL and then convert to a matrix, probably using the "as" method.
THK
