[Gdal-dev] Need Help compiling OGR sample in linux
vdharan nadra
vdharan2001 at gmail.com
Sat Nov 10 08:11:25 EST 2007
My g++ version is 4.1.1 so i decided to use C API.
Iam able to get it working.
Thank you very much.
Regards,
N.Vidhiyadharan
On 11/8/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> vdharan nadra wrote:
> > Hi,
> > Can any one please provide me the step by step procedure to compile
> > the following sample in linux.
> > I have installed fwtools. Iam new to linux environment.
> Hi,
> I was able to build this program using the command:
> g++ -I/usr3/pkg4/OpenEV_FW_Tree/FWTools/include
> -L/usr3/pkg4/OpenEV_FW_Tree/FWTools/lib test1.cpp -lgdal -o test1
> Because you are using C++, there are fairly compiler version specific
> linkage issues and you will need to use a version of g++ compatible with
> g++ 3.2.3. And 3.2.x would be fine. 4.x likely not.
> If you were to rework your program to use the equivelent C API this
> problem would not exist.
> I also found I had to source the fwtools_env.sh script first in order
> to set LD_LIBRARY_PATH properly so that dependent libraries were found.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
