[Gdal-dev] PCI .pix: only reading 1 band
Matt Wilkie
matt.wilkie at gov.yk.ca
Sat Nov 10 15:19:38 EST 2007
In trying to do some stuff today I noticed that the gdal utilities are
only reading a single band of PCI .pix images. Is this normal? Has it
always been this way? I think I remember using gdal before on these but,
as I've publicly proven here in the past my memory is not so reliable... ;-)
GDAL 1.5dev, FWTools 1.4.2, released 2007/11/05
Here is gdalinfo output for a 6 channel .pix:
gdalinfo y:\ImageRepository\Landsat7\Orthos\Mosaic\oYukonMosaic15m.pix
Driver: PCIDSK/PCIDSK Database File
Files: y:\ImageRepository\Landsat7\Orthos\Mosaic\oYukonMosaic15m.pix
Size is 64523, 81767
Coordinate System is:
PROJCS["unnamed",
GEOGCS["Unknown datum based upon the GRS 1980 ellipsoid",
DATUM["Not specified (based on GRS 1980 spheroid)",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Albers_Conic_Equal_Area"],
PARAMETER["standard_parallel_1",61.6666666666667],
PARAMETER["standard_parallel_2",68],
PARAMETER["latitude_of_center",59],
PARAMETER["longitude_of_center",-132.5],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",500000],
UNIT["Meter",1]]
Origin = (17475.000000000000000,1722705.000000000000000)
Pixel Size = (15.000000000000000,-15.000000000000000)
Metadata:
SOFTWARE=PACEV9.1
FILE_ID=c_\1mosaic\YukonMosaic15m.pix
GENERATING_FACILITY=PCI Inc., Richmond Hill, Canada
DESCRIPTION1=
DESCRIPTION2=
DATE_OF_CREATION=10_13 27Mar2002
DATE_OF_UPDATE=10_17 27Mar2002
Corner Coordinates:
Upper Left ( 17475.000, 1722705.000) (144d54'58.37"W, 69d32'29.93"N)
Lower Left ( 17475.000, 496200.000) (140d48'47.92"W, 58d40'49.61"N)
Upper Right ( 985320.000, 1722705.000) (120d 0'49.34"W, 69d32'12.29"N)
Lower Right ( 985320.000, 496200.000) (124d 8'20.73"W, 58d40'37.73"N)
Center ( 501397.500, 1109452.500) (132d28'15.27"W, 64d28'12.10"N)
Band 1 Block=64523x1 Type=Byte, ColorInterp=Undefined
Description = Contents Not Specified
Overviews: 21507x27255, 7169x9085, 2390x3028
Metadata:
UNITS=
HISTORY1=orthoen_output mosaic
10_
17 27Mar2002
LAYER_CRC=0x6423
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
