[Gdal-dev] Re: RFC 10
Mon Nov 12 15:36:51 EST 2007
Andrey Kiselev wrote:
> 2. Introduce new mandatory method for format drivers to determine the
> file format. Now GUI scenario will look like that:
>  - select the file name;
>  - determine a format of that file;
>  - let the user choose open options, specific for that format;
>  - now proceed to GDALOpen(), capable to get options as per RFC 10.
Andrey,
Note that RFC 11: Fast Format Identify, already provides a mechanism
to identify the format of a GDAL dataset.  Presumably you are suggesting
something similar for OGR?
> Frank also suggested to pass encoded open options along with file name
> instead of having the separate parameter in Open() method. With this
> approach we will have different names to pass for format identification
> function and for GDALOpen(): pure file name for the former one and
> name+options for the last one. This will only work when we know the file
> format before opening the file, otherwise we just don't know what
> options are needed.
Note that the approach of encoding driver specific options into the
name is already widely used for OGR - mainly for the various RDBMS
drivers.
I'm not clear on why RFC 10 couldn't be altered to provide a standard
mechanism to encode parameters into the datasource name and go from there.
The issue of applications which don't know the format apriori is not new.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
