[Gdal-dev] Spaceview projection
Enrico Zini
enrico at enricozini.org
Tue Nov 13 09:30:56 EST 2007
Hello,
As part of the effort of geting meteosatlib[1] nearer to gdal, I have to
handle images using the spaceview projection in GDAL. Problem is, I
didn't quote understand how.
It does not seem to be a simple affine transform. The formula to go
from latitude,longitude to projected space that meteosatlib uses is:
Input: m.lat, m.lon. Output: p.x, p.y:
// sublon is the longitude of the point directly below the satellite
// orbitRadius is the radius of the satellite orbit in units of
// earth radius.
// EARTH_RPOL is the polar radius of the Earth.
// EARTH_1E2 and EARTH_E2 are constants for which I didn't find any
// documentation
// Convert to radians
double lat = m.lat * M_PI / 180;
double lon = (m.lon - sublon) * M_PI / 180;
double c_lat;
double r1,r2,r3,rn,rl;
c_lat = atan( EARTH_1E2 * tan(lat) );
rl = EARTH_RPOL / ( sqrt(1.0 - EARTH_E2 * pow(cos(c_lat), 2.0)) );
r1 = orbitRadius - \
rl * cos(c_lat) * cos(lon);
r2 = -rl * cos(c_lat) * sin(lon);
r3 = rl * sin(c_lat);
rn = sqrt( r1*r1 + r2*r2 + r3*r3 );
p.x = atan(-r2 / r1) * 180 / M_PI;
p.y = asin(-r3 / rn) * 180 / M_PI;
To get to the pixel coordinates in the image, a simple extra scaling
step is required, taking as input the pixel resolution and the offset of
the top left pixel:
x = (int)rint((double)p.x * column_resolution) + image_xstart;
y = (int)rint((double)p.y * line_resolution) + image_ystart;
Is there anything like this in GDAL? If not, how can it be added?
Ciao,
Enrico
[1] http://meteosatlib.sourceforge.net/
GPG key: 1024D/797EBFAB 2000-12-05 Enrico Zini <enrico at debian.org>
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071113/4e07a1c3/attachment.bin
