[Gdal-dev] NaN values transformation in funtion Transform from OGRCoordinateTransformation class
Mateusz Loskot mateusz at loskot.net
Thu Nov 15 12:35:33 EST 2007
Miguel Fernandes wrote:
> Hello all,
> I'm using version GDAL_svn_trunk_2007_11_04 and the behaviour I'm
> describing also happens in version 1.4.3. Using library OGR, class
> OGRCoordinateTransformation functions Transform and TransformEx in
> order to make coordinate transformations from latlon to utm29 for
> coastline coordinates that include NaN values in order to detach
> features like islands, the function is transforming the NaN values
> into Inf values. [...] Is this behaviour correct or is this a bug?
It looks like something is wrong. Does it happen for the same coordinate
values or random?
It would be helpful if you could prepare simple test case, a minimal
code snipped (perhaps as a ticket at the http://trac.osgeo.org/gdal/)
presenting how do you use the OGR code, input data and what output you
get. Then it will be possible to try to reproduce this problem and debug.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
