[Gdal-dev] Method to get an image by url?
Thu Nov 15 17:17:07 EST 2007
Joaquim Luis wrote:
> Sorry to insist on this but is libcurl support the only condition to
> access images by url?
> I'm able to access using FWTools but with my build 1.4.3 I get these
> errors.
> And yes, I checked with the dependency walker that libcurl and zlib1
> etc... are all  "non red"
> Thanks
> Joaquim
> ERROR 4: `http://kh.google.com/kh?v=99&n=404&t=tqssrrqstt' does not
> exist in the
> file system,
> and is not recognised as a supported dataset name.
> GDALOpen failed - 4
> `http://kh.google.com/kh?v=99&n=404&t=tqssrrqstt' does not exist in the
> file sys
> tem,
Joaquim,
The other condition is that you need to be using GDAL trunk (aka 1.5).
The HTTP driver does not existing in 1.4.x.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
