[Gdal-dev] Re: RFC 10
Geo Aspects Dev
dev at geoaspects.com
Thu Nov 15 18:12:50 EST 2007
i was rather hoping this RFC would help me to provide a kind of map
browser interface
eg pass each file in a directory (or any file list for that matter)
and have GDAL/OGR driver say which it would be able to open, so i
could highlight (or make selectable) only those "genuine" map files.
Not sure how that would work, if I needed to provide options/
parameters up front?
just my specific perspective on this of course ...
Tim
On 15 Nov 2007, at 19:47, Frank Warmerdam wrote:
>>> I'm not clear on why RFC 10 couldn't be altered to provide a
>>> standard
>>> mechanism to encode parameters into the datasource name and go
>>> from there.
>>> The issue of applications which don't know the format apriori is
>>> not new.
>> I think it might be not easy to find common syntax used across all
>> drivers. For example, if we decided to delimit options with @,
>> perhaps
>> there are some drivers that use @ token in its native connection
>> string.
>> IMO, options interface should be defined as common to all drivers,
>> but
>> not using syntax specific to a driver.
> Mateusz,
> Yes, that was my intent. To "package" lists of options in a
> standard way
> with well understood escaping and quoting rules. A mechanism that
> could
> be applied to new drivers, and in some hopefully not-too-disruptive
> fashion
> applied to old drivers with options in the datasource name.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://
> osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
