[Gdal-dev] NetCDF driver bug fix
Mateusz Loskot
mateusz at loskot.net
Fri Nov 23 06:07:46 EST 2007
Mario.Cruz at esa.int wrote:
> Sorry to revive a seemingly dead thread, but I was revisiting the code
> while upgrading to the now forbidden 1.4.3 release, and realized that the
> submitted patch is seriously ill, i.e. IT DOES NOT WORK for any attribute
> type except strings. Explaining why it does not work is left as an
> exercise for the reader.
Mario,
Thanks for this review.
> Anyway, solved the reported bug with a smaller (and now hopefully
> type-safe) set of changes to the code, but I'll try to follow due
> procedure this time around and submit both the bug and suggested
> correction through the bug tracker system.
Yes, this is a very good idea to use Trac for submitting patches.
Thanks for your contribution!
Cheers
Mateusz Loskot
http://mateusz.loskot.net
