[gdal-dev] OGRGeometry creation
mchapman at texelinc.com mchapman at texelinc.com
Fri Nov 23 12:35:27 EST 2007
Look at your if statement.  You are saying if ier equals err_none is true when it should be ier not equal ogr_errnone.  U have a logical operator wrong for error check. Your code is the problem.
Martin
Sent via BlackBerry by AT&T
-----Original Message-----
Date: Fri, 23 Nov 2007 15:24:35
To:gdal-dev at lists.osgeo.org
Subject: [gdal-dev] OGRGeometry creation
Dear Colleagues !
I try to create geometry object using wkt-string. I do
    OGRGeometry * poOGRGeom;
    const char* obWkt = "POLYGON((...,...))";
    char * pszWkt = new char [strlen (obWkt)];
     strncpy (pszWkt, obWkt, strlen (obWkt));
    OGRSpatialReference *ref = new OGRSpatialReference ();
    OGRErr ier = OGRGeometryFactory::createFromWkt (&pszWkt, ref, &poOGRGeom);
    if (ier == OGRERR_NONE)
        char ** wkt = new char*;
        wkt[0] = new char[1000];
        poOGRGeom->exportToWkt (wkt);
This code works fine under Linux, but under Windows (Visual Studio 2003) it fails on call of any function-member OGRGeometry class. Where is the troubles ?
Best regards,
Sincerely yours,
Yuriy Rusinov _______________________________________________
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
