[gdal-dev] GDAL/OGR 1.4.4 Release Candidate 1 -- GOOD news
Frank Warmerdam
warmerdam at pobox.com
Fri Nov 23 21:52:46 EST 2007
Joaquim Luis wrote:
> Hi all
> By mistake I compiled this version with the Intel compiler and, contrary
> to a previous attempt, everything run smooth. The only exception was
> this warning
> "d:\programas\gdal-1.4.4\port\cpl_string.cpp(796) : warning C4700: local
> variable 'args' used without having been initialized"
Joaquim,
This is caused by a missing va_start() in the CSLAppendPrintf() function.
It seems I screwed up fixes for bug #1979 in r12683. I'm not sure how
serious this is though. As far as I can see, the only code using
CSLAppendPrintf() is in MITAB:
ogr/ogrsf_frmts/mitab/mitab_tabview.cpp:
m_papszTABFnames = CSLAppendPrintf(m_papszTABFnames, "%s%s%d.tab",
Daniel - can you easily test the code this relates to? I have committed fixes
for this in trunk and 1.4 branch in case we need to cut a new RC with this.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
