[gdal-dev] GDAL and PROJ.4 in compiling
Mateusz Loskot
mateusz at loskot.net
Tue Nov 27 20:59:13 EST 2007
Limei Ran wrote:
> Hi Mateusz:
> Thanks for your help. Unfortunately, PROJ.4 is not installed in /usr or
> /usr/local. I do not have LD_LIBRARY_PATH point to PROJ.4.
> There are five dirs under PROJ.4 installation local dir: bin/ include/
> lib/ man/ share/. I am not sure which dir I should use in configure.
> Could I fix it by configuring:
> configure --with-static-proj4=/nas/lran/soft/proj.4/local
> or
> configure --with-static-proj4=/nas/lran/soft/proj.4/local/lib
You can use installation prefix:
and the 'lib' subdirectory should be found automagically.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
