[Gdal-dev] Issue with 1.4.2 gdalwarp
Tue Oct 2 23:30:27 EDT 2007
On 10/2/07, nashirak <nashirak at gmail.com> wrote:
> I was looking into why the 1.4.2 version of GDAL seemed to remove the
> geospatial information when attempting to rotate the image to north up.  I
> ran across this post:
> http://lists.maptools.org/pipermail/gdal-dev/2007-June/013287.html
> I downloaded FWTools 1.3.7, as suggested here
> http://lists.maptools.org/pipermail/gdal-dev/2007-June/013290.html
> ,  and tried to use the gdalwarp that came with the FWTools package.  This
> program did not remove the geospatial information and gave me a correct
> result.  Is there a fix for this in a later GDAL version?  What version of
> GDAL was FWTool 1.3.7 compiled against?
Clayton,
FWTools 1.3.7 is built against GDAL "trunk" as of the time it was
built (not GDAL 1.4.x).
Best regards,
