[Gdal-dev] Re: Issue with 1.4.2 gdalwarp
nashirak nashirak at gmail.com
Wed Oct 3 09:44:11 EDT 2007
> Clayton,
> FWTools 1.3.7 is built against GDAL "trunk" as of the time it was
> built (not GDAL 1.4.x).
Does this mean that I pull from the current Subversion trunk to get the fix,
or was the fix built against an older version of the subversion trunk?
Thanks.
Clayton Bluhm
Home: nashirak at gmail.com
"si vis pacem para bellum" -- Vegetius
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071003/396ec135/attachment.html
