[Gdal-dev] Read hdf band, inverse dimensions
Lucena, Ivan
ivan.lucena at pmldnet.com
Thu Oct 4 23:28:22 EDT 2007
Jan,
I once had a problem just like that and the solution was to
translate/project the data to geotiffs using "Modis Swath Reprojection
Tool" and then go back to GDAL to work with the tifs.
Ref.: [http://edcdaac.usgs.gov/landdaac/tools/mrtswath/]
Good luck,
Ivan
Jan Cermak wrote:
> Hi!
> I am trying to read a band from a MODIS hdf file. This in itself does
> not seem to be a problematic thing to do; however, the dimensions of the
> array are inverse.
> gdalinfo myfile.hdf (or gdal.Dataset.GetSubDatasets) yields:
> [snip]
> SUBDATASET_52_NAME=HDF4_EOS:EOS_SWATH:'myfile.hdf':mod06:Cloud_Mask_1km
> SUBDATASET_52_DESC=[2040x1354x2] Cloud_Mask_1km mod06 (8-bit integer)
> [snip]
> So there are two bands of size 2040x1354 in my subdataset. However, in
> order for gdal to recognize them as two bands the dimensions would have
> to be [2x2040x1354].
> Accordingly, when I do
> gdalinfo HDF4_EOS:EOS_SWATH:'myfile.hdf':mod06:Cloud_Mask_1km
> I get information on 2040 different bands, each of size 1354x2
> What can I do to get my two bands? I know I could read 2040 datasets and
> then reassemble them. But that takes 2/3 eternity.
> All help appreciated!
> Jan
