[Gdal-dev] HDF EOS segmentation fault
Jan Cermak jcermak at atmos.washington.edu
Tue Oct 9 13:59:59 EDT 2007
Frank Warmerdam wrote:
> Jan Cermak wrote:
>> Hi,
>> When I read in an hdfeos dataset from a MYD06 file I get a segfault of
>> the following type:
>> *** glibc detected *** python: double free or corruption (fasttop):
>> 0x081b8d90 ***
>> This occurs either at one of the steps following the data read or at
>> the termination of the program. There does not seem to be a pattern.
>> Here is some example code:
>> #!/usr/bin/env python
>> import gdal
>> DSname='HDF4_EOS:EOS_SWATH:"/home/jancer/data/tmp/MODIS/MYD06_L2.A2006220.1315.005.2006222153137.hdf":mod06:Cloud_Optical_Thickness'
>> DSobj = gdal.Open(DSname)
>> data = DSobj.ReadAsArray()
>> data.shape
>> halfdata = data/2.
>> There is a sample file at
>> ftp://ladsweb.nascom.nasa.gov/allData/5/MYD06_L2/2006/220/MYD06_L2.A2006220.1315.005.2006222153137.hdf
> Jan,
> I believe you are experiencing one of several bugs that have been fixed
> in the last six months or so in GDAL's HDF driver.  Can you update to
> either a 1.4 branch snapshot or a trunk snapshot from:
>  http://download.osgeo.org/gdal/daily
> and see if the problem still persists? (or perhaps grab a recent FWTools
> build).
> Best regards,
Hi Frank,
actually that was what I suspected when the problem first occurred. So I
updated to gdal 1.4.2 (1007/06/27) a week ago. This didn't make any
difference though. I just tried the latest nightly build but this gives
me an import error, so I reverted to 1.4.2
By the way, I only get the segfault for MYD06 files. MYD021km etc. work
fine.
Any suggestions?
Jan
