[Gdal-dev] Shapfiles and Projections
Dean Mikkelsen
dcmikkelsen at shaw.ca
Tue Oct 9 14:36:27 EDT 2007
Hi Kent,
The Shapefile technical definition can also be found here:
http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf
and
http://facweb.knowlton.ohio-state.edu/selhami/crpinfo/teaching/CRP608/Shape%20file%20structure.doc
Note that the .prj is optional and was a late addition to the Shapefile definition (not sure myself when it came along, but it was not present in the Original White paper).
Cheers,
Dean
----- Original Message -----
Date: Tuesday, October 9, 2007 11:08 am
Subject: Re: [Gdal-dev] Shapfiles and Projections
To: gdal-dev at lists.maptools.org
> Thank you all for your assistance. The gdal/ogr library can read
> the shapefile
> if the directory also contains the dbf and shx files that came
> along with the
> shp file. Specific responses below.
> -----Original Message-----
> > gdrinfo doesn't seem to find a projection in a shapefile
> describiing roads
> > (from the National Atlas). I was expecting something
> like what gdalinfo
> > finds in a geotiff file. Could someone point me towards
> the answer?
> Martin Chapman wrote:
> > Make sure there is a .prj file with the same name as the
> .shp file. NTAD
> > data doesn't always come with these projection
> files. If you read the .txt
> > file with the shape file it will tell you what datum it
> is using. Attached
> > is a wgs84 prj file that should work if you rename it to
> be the same as your
> > .shp file. NTAD is generally in WGS84.
> Hmmm ... I didn't do that; there is no prj file but it now seems
> to work.
> Ed McNierney wrote:
> > Unfortunately, the concept of projections and coordinate
> systems in general
> > was late in coming to the shapefile format, and many (if
> not most)
> > shapefiles have no projection/coordinate information
> with them.
> > Your shapefile should have a .txt file with it
> (presumably roadtrl20.txt
> > if you're using the roads layer from the National Atlas)
> and it will
> > contain this information:
> <clip>
> Yes, a txt file was supplied and it has information similar to
> your example.
> However it doesn't seem to be used. I'm still developing my
> application and so
> I'll find out soon enough if it is needed by hiding or not
> hiding the txt file.
> Frank Warmerdam wrote:
> > I assume you were using ogrinfo?
> > It will report coordinate system info if it finds
> it. Does your shapefile
> > dataset include a .prj file? If not, there
> is not declared coordinate
> > system for the file.
> Yes, my mistake, I am using ogrinfo. No prj file was supplied
> but it seems that
> information was provided in the txt file.
> Kent
> Pittsburgh Supercomputing Center
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Dean C. Mikkelsen, B.Sc., P.Eng.
Terra ETL Ltd.
Victoria, B.C., Canada
Phone: +1 (250) 361-6672
http://www.terraetl.com
Consulting in Geodesy & GIS for the Natural Resources
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071009/bf7a9ef8/attachment.html
