[Gdal-dev] HDF EOS segmentation fault
Jan Cermak
jcermak at atmos.washington.edu
Tue Oct 9 17:05:30 EDT 2007
Frank Warmerdam wrote:
> Jan,
> I believe you are specifically running into:
> http://trac.osgeo.org/gdal/ticket/1701
> Fixed as:
> http://trac.osgeo.org/gdal/changeset/11742
> I believe this fix was post 1.4.2, so you would need up to update to
> the stable branch (1.4) nightly snapshot. I don't know what import
> error you encountered, but I would suggest trying to work through it.
> (or using FWTools for the script).
> Best regards,
Hi Frank,
Updating to stable branch nightly seems to have fixed it. Thanks very much!
All best,
Jan
