[Gdal-dev] ng-python build
Howard Butler hobu.inc at gmail.com
Fri Oct 12 00:34:57 EDT 2007
On Oct 11, 2007, at 10:55 PM, William Kyngesburye wrote:
> As I worked on some OSX framework build issues, I noticed a couple
> odd ng-python build items.
> - After configuring to build ng-python, make doesn't build *any*
> python bindings.  It looks like the makefile default target doesn't
> refer to the swig-target, just the old py-target.  BUT, install
> does - the install-actions target runs a make install in the swig
> dir, which ends up building ng-python.
I think this was because of libtool and linking trouble with -lgdal
as it is built in the tree.  I think Kevin was the one who originally
did the target for the ng bindings.  I have always built them by
hand, but I am expecting to deal with these issues before the 1.5
release.  Can you please file a ticket for this one and pick the
PythonBindings as the component?
> - ng-python installs in $prefix.  This ends up being installed
> where-ever GDAL is installed, in the subdir thereof specified in
> the python distutils (something like lib/python2.5/site-packages).
> Is this intentional?  Shouldn't it be left completely up to
> distutils so it gets installed in the default python site-packages
> dir?
This is what the old bindings did as well, which is why it currently
does this by default.  However, with the ng bindings, the situation
is more inconsistent than that:
-- If setuptools is installed, use that to build and do "install --
root / --single-version-externally-managed".  By default this means
an egg file gets put in your Python path (typically site-packages)
-- If setuptools is not installed, install in --prefix as before.
What makes the most sense for installation and building of the Python
bindings?  There are so many different ways to skin this cat now that
we are using setuptools/distutils by default.  I'd like everyone to
chime in who has an opinion.  I think putting stuff in --prefix by
default is confusing for most folks, but installing stuff in the root
of your Python install isn't too friendly either...
As things are currently defined, setuptools is used *by default* if
configure or setup.py determines that it is available. Regular
distutils is then used if setuptools isn't available.  I would hate
to *require* setuptools, but it would simplify troubleshooting
things.  Our default install: targets basically install the bindings
the same way regardless of whether or not setuptools is available,
and the major benefit is if you want to hand build things, you have a
lot more options.
My opinions:
-- I really like setuptools for the 'develop' target and even for
eggs now that we use them on the osx buildbot slave (everything is
self-contained and it doesn't end up polluting the rest of my machine
with new and possibly broken bindings and we don't have to do
sys.path hacking). I can see providing the ng bindings as eggs for
windows, for example.
-- './configure --with-python;make;make install' needs to do the most
straightforward thing for Python users (we need to define what that
is, and it is my opinion that installing in --prefix *isn't* it).
Someone wanting to do fancier stuff should have to run setup.py
themselves.
Howard
PS.  This discussion reminded me of the best feature of the ng
bindings in the upcoming 1.5 release... docs!  I figured out a way to
incorporate the doxygen docs into docstrings as part of the swig
generation.  pydoc away... :)
