[Gdal-dev] Re: [postgis-users] OGR2OGR conversion from PostGIS to
MapInfo issue
Mateusz Loskot
mateusz at loskot.net
Mon Oct 15 09:34:58 EDT 2007
Obe, Regina wrote:
> I apologize for this cross-posting, but wasn't quite sure which list
> would be best.
Regina,
I believe the best list is the official mailing list of GDAL project:
gdal-dev at lists.maptools.org
> I converted a query from PostGIS to MapInfo for one of our GIS
> specialists here, and apparently all the fields came out as varchar(254)
> and when they try to resave the file in MapInfo - it doesn't allow them
> to (I forget the error). Aside from that, reading the file seems fine
> and you can see the features. If I do the same but to shape format,
> then the fields have the correct field sizes and everything.
> Is there something I am doing wrong here or is this just a limitation of
> the Ogr Mapinfo driver?
varchar(256) is a default width of string field in MapInfo format,
if not specified explicitly (http://www.gdal.org/ogr/drv_mitab.html)
I made a short test and it shows that columns are differently
recognized for layer based on SQL query than layer based on a table:
1. Reading point table as a layer determines wiedth of columns:
mloskot at dog:~/dev/gdal/_svn/trunk/gdal$ ogr/ogrinfo -ro PG:dbname=test
point -so
INFO: Open of `PG:dbname=test'
using driver `PostgreSQL' successful.
Layer name: point
Geometry: Point
Feature Count: 53
Extent: (11.660233, 48.320915) - (21.675484, 53.763435)
Layer SRS WKT:
(unknown)
Geometry Column = the_geom
altitude: String (6.0)
gid: Integer (0.0)
lat: String (12.0)
lon: String (12.0)
longname: String (17.0)
recnum: String (6.0)
2. If layer is based on SQL query, no details about columns width is given:
-sql "SELECT gid,name,recnum FROM point" -so
Layer name: sql_statement
Geometry: Unknown (any)
Feature Count: 53
Layer SRS WKT:
(unknown)
gid: Integer (0.0)
recnum: String (0.0)
In case 2., default value (254) is used, that's why you get varchar(254).
I'd recognize it as correct and expected behavior of OGR,
although a little strange or even surprising :-)
p.s. I added gdal-dev at lists.maptools.org to CC
Cheers
Mateusz Loskot
http://mateusz.loskot.net
