[Gdal-dev] jasper for very large jpeg 2000 images
Trent M Hare
thare at usgs.gov
Mon Oct 15 19:16:15 EDT 2007
Kurt,
Considering you said HiRISE I though I would chime in.
If you have ISIS3 and GDAL available, try this:
http://isis.astrogeology.usgs.gov/IsisSupport/viewtopic.php?t=1456
Notice should have a direct method in GDAL to read ISIS3 images in the
foreseeable future.
Regards,
Trent
Kurt Schwehr <schwehr at ccom.unh.edu>
Sent by: gdal-dev-bounces at lists.maptools.org
10/15/2007 01:24 PM
To
gdal-dev at lists.maptools.org
cc
Steve Levoe <steve.levoe at jpl.nasa.gov>
Subject
Hi All,
Is there a way to allow very large images to make it through the
drivers? I'm trying to convert HiRise images from Mars without luck.
For example trying to subset a quicklook image
gdal_translate -of PNG -srcwin 10 10 1000 1000
Input file size is 32369, 95295
error: cannot decode code stream
gdal_translate(22843) malloc: *** vm_allocate(size=3084607488) failed
(error code=3)
gdal_translate(22843) malloc: *** error: can't allocate region
gdal_translate(22843) malloc: *** set a breakpoint in szone_error to debug
ERROR 2: Internalize failed
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
libpng error: No IDATs written into file
Abort trap
I'm guessing that this is an architectural issue with gdal?
Thanks,
-kurt
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071015/81b3783c/attachment.html
