[Gdal-dev] Parameter names in swig bindings
Ari Jolma ari.jolma at tkk.fi
Tue Oct 16 12:52:28 EDT 2007
Brian Hamlin kirjoitti:
> it looks like in Perl it should be
> Geo::OGR::ExecuteSQL()
> but using trunk sources I get
>   can't locate auto/Geo/OGR/Driver/ExecuteSQL.al in @INC(xxx)
It's a DataSource method, i.e.
$ds = Geo::OGR::DataSource somehow
$layer = $ds->ExecuteSQL($sql);
although this does not work with latest from repository since it
complains geom being undefined
... more woes because of parameter names:
I have a general requirement that OGRGeometryShadow* other should be
non-null. In AddGeometryDirectly there is a "%apply SWIGTYPE *DISOWN" on
it and after the method a "%clear OGRGeometryShadow* other;", which
seems to clear _both_ DISOWN and the non-null requirement.
I guess this is just more reasons to press on putting the checks into C API.
I run into this problem because I'm getting segfaults with the latest
latest from repository somewhere in my OGR test code where I add
geometries into a multigeometry. This problem is both in Windows and Linux.
Ari
> On Oct 16, 2007, at 3:06 AM, Ari Jolma wrote:
>> I assume there's no problem in changing the parameter names in the
>> bindings? I'd like to rename the geom parameter to something else,
>> probably spatialFilter.
>> This because there's now a problem with the Perl typemap, which  says
>> that  geom must not  be null (as is the case where it is used
>> elsewhere) and in ExecuteSQL  geom is usually null.
>> Ari
>> Prof. Ari Jolma
>> Geoinformaatio- ja paikannustekniikka / Geoinformation and positioning
>> Teknillinen Korkeakoulu / Helsinki University of Technology
>> tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
>> Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
Prof. Ari Jolma
