[Gdal-dev] Parameter names in swig bindings
Ari Jolma
ari.jolma at tkk.fi
Tue Oct 16 14:47:27 EDT 2007
Tamas Szekeres kirjoitti:
> Ari,
> I don't see any problems with the perl builds out there. Could you
> describe the issue in more detail?
Just one of those cases again where "make clean; make" does not work. No
problems any more -- except with the parameter names. Do you have any
opinion on them?
Ari
> Best regards,
> Tamas
> 2007/10/16, Ari Jolma <ari.jolma at tkk.fi>:
>> I assume there's no problem in changing the parameter names in the
>> bindings? I'd like to rename the geom parameter to something else,
>> probably spatialFilter.
>> This because there's now a problem with the Perl typemap, which says
>> that geom must not be null (as is the case where it is used elsewhere)
>> and in ExecuteSQL geom is usually null.
>> Ari
>> Prof. Ari Jolma
>> Geoinformaatio- ja paikannustekniikka / Geoinformation and positioning
>> Teknillinen Korkeakoulu / Helsinki University of Technology
>> tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
>> Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
Prof. Ari Jolma
