[Gdal-dev] Another NetCDF driver bug fix
Frank Warmerdam
warmerdam at pobox.com
Wed Oct 17 18:27:23 EDT 2007
Joaquim Luis wrote:
> Hi,
> Although there is no track ticked assigned to it, it has been often
> referred here the problem of the
> netCDF up-down flipping (and Surfer grids btw).
> The problem is that SetProjection() in netcdfdataset.cpp assumes the Y
> coordinates vector is given
> in descending order. So line nº 1087 (todays - 17-10-2007 svn version)
> poDS->adfGeoTransform[5] = (( pdfYCoord[ydim-1] -
> pdfYCoord[0] ) /
> ( poDS->nRasterYSize - 1 ));
> and line 1098
> poDS->adfGeoTransform[3] = pdfYCoord[0]
> - (poDS->adfGeoTransform[5] / 2);
> are expected to give a negative dy and the top left point.
> However, the most common practice for Y orientation is increasing from
> bottom to top and not
> the other way around.
> To correct this problem one can add, after line 1089
> if ( poDS->adfGeoTransform[5] > 0 )
> poDS->adfGeoTransform[5] *= -1;
> which will work for both Y orientations
> This corrects for the bad Upper Left when Y "grows up", but I here don't
> know a solution that works
> for both Y orientation cases.
> poDS->adfGeoTransform[3] = pdfYCoord[ydim-1]
> A related note. With the risk of looking impatient (which I am) this
> netCDF driver bugs are trailing
> for such a long time. Can't they be killed once for all?
Joaquim,
I believe we need someone to step up and take ownership of the netcdf
driver. It seems that Denis Nadeau does not have the time to do a lot of
new work on it, and I have been trying to duck these issues. Are you
interested in taking on responsibility for it?
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
