[Gdal-dev] best approach for writing AI grids
Gregory, Matthew matt.gregory at oregonstate.edu
Mon Oct 22 12:12:47 EDT 2007
Frank Warmerdam wrote:
> Option (3) might be port the gio driver to current GDAL,
> possibly as a runtime loaded driver.  I can't think of any
> reason it would be a problem to get the old driver working
> with current GDAL - assuming you are comfortable building
> GDAL yourself and doing just a bit of build-hacking yourself.
Thanks Frank,
A great suggestion.  I have a naïve follow-up question.  You mention loading the GIO driver at runtime.  Is this equivalent to:
GDALDriverManager* t = GetGDALDriverManager();
GDALDriver* d = t->GetDriverByName("GIO");
t->RegisterDriver(d);
If not, can you explain or point me to documentation which explains loading run-time drivers?
thanks, matt
