[Gdal-dev] Null-Pointer in GDALOpen?
Tom Kazimiers
2voodoo at gmx.de
Mon Oct 22 16:35:26 EDT 2007
Hi again,
I figured out that the conversion of "\a.tif" leads to a
missinterpretation in translation to char and therefore the strange
symbol comes up.
Not clear is why the function did not break in this case.
I traced a bit through the gdal-geotiff-opening process and figured out
that everything works fine until this part
in GDALDataset *GTiffDataset::Open( GDALOpenInfo * poOpenInfo ) in
geotiff.cpp
/* Try opening the dataset. */
if( poOpenInfo->eAccess == GA_ReadOnly )
hTIFF = VSI_TIFFOpen( poOpenInfo->pszFilename, "r" );
else
hTIFF = VSI_TIFFOpen( poOpenInfo->pszFilename, "r+" );
the code after this is not reached anymore.
If I have time tomorrow I will go through the code in tifvsi.cpp
bye
Tom
