[Gdal-dev] 1.4.3 build and NG bindings
William Kyngesburye
woklist at kyngchaos.com
Mon Oct 29 18:43:08 EDT 2007
On Oct 29, 2007, at 4:24 PM, Brian Hamlin wrote:
> :-) well, this is apparently not 100% settled out there
> I used the Mac specific installer for python 2.5.1, and I didn't get
> anything like that
> I have a /usr/bin and /usr/local/bin which end up calling either
> /System/Library or /Library/Frameworks pythons
The /Library/frameworks one should be the correct python 2.5.
Have you upgraded your system a few times from before 10.3? The old
default tcsh init files might interfere with the bash init files (it's
been so long, but I think it happened to me). I can't remember what
these files are.
Or maybe something is simply overriding PATH in .bash_profile after
the python path is added.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
