[Gdal-dev] [Fwd: strange problem compiling against ndarrayobject.h]
Vincent Schut
schut at sarvision.nl
Wed Oct 31 12:21:59 EDT 2007
sorry if this arrives twice...
Hi numpy and/or gdal guru's,
I'm suddenly getting into trouble compiling gdal's python extension,
when it includes ndarrayobject.h from numpy. First it complains about my
python not being unicode, though I am sure it is unicode, and then it
bails out with all kinds of errors (see snippet below).
Numpy people, please read on even though this might seem a gdal problem,
because it clearly is numpy related, see the snippet...
I've tried everything I could think of, but to no avail. I hope one of
you can give me a hint, because I'm kind of clueless, and even don't
know in what direction I should search...
Here is a paste from the output from building (python setup.py build) in
the gdal/swig/python dir.
make[2]: Entering directory `/usr/local/src/gdal/swig/python'
numpy include /usr/lib64/python2.5/site-packages/numpy/core/include
running build
running build_py
creating build
creating build/lib.linux-x86_64-2.5
copying gdal.py -> build/lib.linux-x86_64-2.5
copying ogr.py -> build/lib.linux-x86_64-2.5
copying osr.py -> build/lib.linux-x86_64-2.5
copying gdalconst.py -> build/lib.linux-x86_64-2.5
creating build/lib.linux-x86_64-2.5/osgeo
copying osgeo/gdalnumeric.py -> build/lib.linux-x86_64-2.5/osgeo
copying osgeo/gdalconst.py -> build/lib.linux-x86_64-2.5/osgeo
copying osgeo/__init__.py -> build/lib.linux-x86_64-2.5/osgeo
copying osgeo/osr.py -> build/lib.linux-x86_64-2.5/osgeo
copying osgeo/gdal_array.py -> build/lib.linux-x86_64-2.5/osgeo
copying osgeo/gdal.py -> build/lib.linux-x86_64-2.5/osgeo
copying osgeo/ogr.py -> build/lib.linux-x86_64-2.5/osgeo
running build_ext
building 'osgeo._gdal' extension
C compiler: x86_64-pc-linux-gnu-gcc -pthread -fno-strict-aliasing
-DNDEBUG -fPIC
creating build/temp.linux-x86_64-2.5
creating build/temp.linux-x86_64-2.5/extensions
compile options: '-I../../port -I../../gcore -I../../alg -I../../ogr
-I/usr/lib64/python2.5/site-packages/numpy/core/include
-I/usr/include/python2.5 -c'
x86_64-pc-linux-gnu-gcc: extensions/gdal_wrap.cpp
extensions/gdal_wrap.cpp: In function ‘PyObject*
_wrap_MajorObject_SetMetadata__SWIG_0(PyObject*, PyObject*)’:
extensions/gdal_wrap.cpp:4570: warning: deprecated conversion from
string constant to ‘char*’
x86_64-pc-linux-gnu-g++ -pthread -shared
build/temp.linux-x86_64-2.5/extensions/gdal_wrap.o -L../../.libs -L../..
-L/usr/lib64 -lgdal -lpython2.5 -o build/lib.linux-x86_64-2.5/osgeo/_gdal.so
building 'osgeo._gdalconst' extension
-DNDEBUG -fPIC
x86_64-pc-linux-gnu-gcc: extensions/gdalconst_wrap.c
x86_64-pc-linux-gnu-gcc -pthread -shared
build/temp.linux-x86_64-2.5/extensions/gdalconst_wrap.o -L../../.libs
-L../.. -L/usr/lib64 -lgdal -lpython2.5 -o
build/lib.linux-x86_64-2.5/osgeo/_gdalconst.so
building 'osgeo._osr' extension
-DNDEBUG -fPIC
x86_64-pc-linux-gnu-gcc: extensions/osr_wrap.cpp
build/temp.linux-x86_64-2.5/extensions/osr_wrap.o -L../../.libs -L../..
-L/usr/lib64 -lgdal -lpython2.5 -o build/lib.linux-x86_64-2.5/osgeo/_osr.so
building 'osgeo._ogr' extension
-DNDEBUG -fPIC
x86_64-pc-linux-gnu-gcc: extensions/ogr_wrap.cpp
build/temp.linux-x86_64-2.5/extensions/ogr_wrap.o -L../../.libs -L../..
-L/usr/lib64 -lgdal -lpython2.5 -o build/lib.linux-x86_64-2.5/osgeo/_ogr.so
building 'osgeo._gdal_array' extension
-DNDEBUG -fPIC
x86_64-pc-linux-gnu-gcc: extensions/_gdal_array.cpp
In file included from
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/arrayobject.h:14,
from extensions/gdal_array.h:10,
from extensions/_gdal_array.cpp:33:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:92:2:
error: #error Must use Python with unicode enabled.
In file included from /usr/include/python2.5/Python.h:62,
from extensions/gdal_array.h:16,
/usr/include/python2.5/pyport.h:105:1: warning: "PY_SSIZE_T_MAX" redefined
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:931:1:
warning: this is the location of the previous definition
/usr/include/python2.5/pyport.h:107:1: warning: "PY_SSIZE_T_MIN" redefined
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:932:1:
In file included from /usr/include/python2.5/Python.h:131,
/usr/include/python2.5/abstract.h:762:1: warning: "PyIndex_Check" redefined
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:937:1:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:919:
error: ‘Py_intptr_t’ does not name a type
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:920:
error: ‘Py_uintptr_t’ does not name a type
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1012:
error: expected initializer before ‘*’ token
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1013:
error: typedef ‘PyArray_SetItemFunc’ is initialized (use __typeof__ instead)
error: ‘PyObject’ was not declared in this scope
error: expected primary-expression before ‘,’ token
error: expected primary-expression before ‘void’
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1015:
error: ‘npy_intp’ has not been declared
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1016:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1026:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1028:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1029:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1031:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1041:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1043:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1044:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1046:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1050:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1052:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1053:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1056:
error: ISO C++ forbids declaration of ‘npy_intp’ with no type
error: expected ‘;’ before ‘*’ token
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1069:
error: ISO C++ forbids declaration of ‘PyArray_GetItemFunc’ with no type
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1070:
error: ISO C++ forbids declaration of ‘PyArray_SetItemFunc’ with no type
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1121:
error: ISO C++ forbids declaration of ‘PyObject’ with no type
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1171:
error: ‘PyObject_HEAD’ does not name a type
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1190:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1194:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1203:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1213:
error: ISO C++ forbids declaration of ‘PyObject_HEAD’ with no type
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1214:
error: expected ‘;’ before ‘char’
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1216:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1217:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1219:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1229:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1238:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1246:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1249:
error: ‘npy_intp’ does not name a type
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1253:
error: ‘PyObject’ has not been declared
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1395:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1396:
error: expected ‘;’ before ‘int’
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1397:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1398:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1399:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1400:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1401:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1402:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1542:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1543:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1544:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1545:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1547:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1596:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1600:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1602:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1604:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1606:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1622:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1624:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1799:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1800:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1802:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:1814,
from
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/__multiarray_api.h:
In function ‘int _import_array()’:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/__multiarray_api.h:945:
error: ‘numpy’ was not declared in this scope
error: ‘PyImport_ImportModule’ was not declared in this scope
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/__multiarray_api.h:946:
error: ‘c_api’ was not declared in this scope
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/__multiarray_api.h:948:
error: ‘PyObject_GetAttrString’ was not declared in this scope
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/__multiarray_api.h:949:
error: ‘Py_DECREF’ was not declared in this scope
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/__multiarray_api.h:950:
error: ‘PyCObject_Check’ was not declared in this scope
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/__multiarray_api.h:951:
error: ‘PyCObject_AsVoidPtr’ was not declared in this scope
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/__multiarray_api.h:953:
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/__multiarray_api.h:958:
error: ‘PyExc_RuntimeError’ was not declared in this scope
error: ‘PyErr_Format’ was not declared in this scope
/usr/include/python2.5/pyport.h: At global scope:
/usr/include/python2.5/pyport.h:97: error: conflicting declaration
‘typedef ssize_t Py_ssize_t’
/usr/lib64/python2.5/site-packages/numpy/core/include/numpy/ndarrayobject.h:930:
error: ‘Py_ssize_t’ has a previous declaration as ‘typedef int Py_ssize_t’
extensions/_gdal_array.cpp: In function ‘void init_gdal_array()’:
extensions/_gdal_array.cpp:118: warning: deprecated conversion from
extensions/_gdal_array.cpp: In destructor ‘virtual
NUMPYDataset::~NUMPYDataset()’:
extensions/_gdal_array.cpp:162: error: ‘struct PyArrayObject’ has no
member named ‘ob_refcnt’
extensions/_gdal_array.cpp: In static member function ‘static
GDALDataset* NUMPYDataset::Open(GDALOpenInfo*)’:
extensions/_gdal_array.cpp:382: error: ‘struct PyArrayObject’ has no
extensions/_gdal_array.cpp:393: error: ‘struct PyArrayObject’ has no
member named ‘dimensions’
extensions/_gdal_array.cpp:394: error: ‘struct PyArrayObject’ has no
member named ‘strides’
extensions/_gdal_array.cpp:395: error: ‘struct PyArrayObject’ has no
extensions/_gdal_array.cpp:396: error: ‘struct PyArrayObject’ has no
extensions/_gdal_array.cpp:397: error: ‘struct PyArrayObject’ has no
extensions/_gdal_array.cpp:398: error: ‘struct PyArrayObject’ has no
extensions/_gdal_array.cpp:404: error: ‘struct PyArrayObject’ has no
extensions/_gdal_array.cpp:405: error: ‘struct PyArrayObject’ has no
extensions/_gdal_array.cpp:406: error: ‘struct PyArrayObject’ has no
extensions/_gdal_array.cpp:407: error: ‘struct PyArrayObject’ has no
extensions/_gdal_array.cpp:418: error: ‘struct PyArrayObject’ has no
member named ‘data’
going on like this for some more, but I hope this suffices...
TIA,
Vincent.
