[Gdal-dev] Using +nadgrids=@null with gdal
ValiSystem vali.system at free.fr
Mon Sep 3 07:10:44 EDT 2007
	Hello list,
I'd like to use the +nadgrids=@null trick described in the last entry
of proj FAQ (http://proj.maptools.org/faq.html), it works perfectly
with cs2cs, but i can't make it work with gdal, lat lon of corners of
my image are modified.
Is this normal ? Is there another way to achieve that (i'd like to
avoid copying entire file using gdal_translate +a_ullr option) ?
