[Gdal-dev] gdal fails on vrt (virtual raster) file
Frank Warmerdam
warmerdam at pobox.com
Wed Sep 5 10:21:30 EDT 2007
WolfgangZ wrote:
> Hi,
> Gdal fails on my virtual raster file that links to JPEG graphics. Map
> size is 17121x12100 pixel and 13.8 MB of filesize (JPEG images).
> Here the command (but also gdal_translate fails with the same error):
> D:\DOP>gdalinfo referenz.vrt
> ERROR 1: libjpeg: Failed to create temporary file
> gdalinfo failed - unable to open 'referenz.vrt'.
> Open GDAL Datasets:
> 1 N DriverIsNULL 512x512x0
> Any help is welcome.
> Wolfgang
Wolfgang,
This is an issue in the JPEG driver. It seems that libjpeg tries to
create a temporary file when an operation (like processing a progressive
jpeg) would require quite a bit of memory. If it fails to create the file
you get the message you see.
I recently changed the amount of memory at which this happens to be 500MB
instead of 1MB in the builtin libjpeg for GDAL (SVN trunk)
http://trac.osgeo.org/gdal/changeset/11706
If you are building GDAL from source, then you might want to apply the
same change.
It might also be sufficient to copy the jpeg file to a directory where
you have read-write access.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
