[Gdal-dev] problems compiling gdal with xerces
Edward Fialkowski
wef1 at cec.wustl.edu
Wed Sep 5 15:26:44 EDT 2007
Sorry, I sent from the wrong e-mail address so the list didn't accept it.
Hey Mateusz, thanks for looking into it. I did just today, finally get Gdal
compiled with Xerces. I just had to find the right jumble of options.
Unfortunately, I wasn't as close as I thought. The whole point for me is to
use this program FeatureServer, which provides WFS data to OpenLayers, a
javascript mapping application.
So, just in case you or anyone are interested, I did get Xerces working:
[root at niceguy ogr]# ./ogrinfo wfs.gml
Had to open data source read-only.
INFO: Open of `wfs.gml'
using driver `GML' successful.
1: GIS
Unfortunately, my FeatureServer request returns an error:
An error occurred: libxerces-c.so.27: cannot open shared object file:
No such file or directory
So, I run /sbin/ldconfig to reload shared libraries. FeatureServer does
indeed recognize the library now, but returns the original error that OGR
cannot read the GML result. So, I check my ogrinfo again, and apparently
xerces is not installed....
So here's my whole routine. If I run make install from gdal directory, the
ogrinfo command-line once again recognizes gml input, but the shared
libraries cannot be loaded for my FeatureServer.
1: GIS
[root at niceguy ogr]# /sbin/ldconfig
ERROR 1: Unable to create Xerces C++ based GML reader, Xerces support
not configured into GDAL/OGR.
ERROR 1: File wfs.gml appears to be GML but the GML reader can't
be instantiated, likely because Xerces support wasn't
configured in.
FAILURE:
Unable to open datasource `wfs.gml' with the following drivers.
-> ESRI Shapefile
-> MapInfo File
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> DGN
-> VRT
-> AVCBin
-> REC
-> Memory
-> CSV
-> GML
-> KML
-> PostgreSQL
Pretty bizarre if you ask me, now I have even less of a clue what to do than
before!
Thanks again for looking into that. If anyone has any random ideas or
suggestions, I'd be happy to hear them.
-Ed
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070905/380b6eff/attachment.html
